I have also gone through wordpress installer and is no different. Not only the google browser. Firefox does not repond either. Even I have to delete the folder airlock to get back access to the administration of wordpress.
I'm confused now. What do you want eyusa? When do you get error? Is it still error 324 which is not related to wordpress at all? Give as much details as you can, attach image, etc.
From the beginning I get the error 324 when I activate the theme airlock. Not so with the activation of other themes. I can not send pictures because the only thing that comes up is "Error 324 (net:: ERR_EMPTY_RESPONSE)" and from this error I can not access wordpress administration. I have to delete the folder airlock from the FTP program to access the administration of wordpress I do not know if wordpress problem or my virtual server (this in aruba.it) The issue is that I have looked for another topic and I have no problem. So, if not resolved, I will ask paypal money back.
Everyone needs urgent help ;-)
I don't know what kind of error is that but google turned me here http://www.google.com/support/forum/p/Chrome/thread?tid=19043fff689eff09&hl=en and it seems not related to Airlock itself.
Try to upload theme via wordpress theme installer, maybe you will have more luck http://codex.wordpress.org/Using_Themes#Adding_New_Themes_using_the_Administration_Panel
If you like send me via private msg your FTP login data, and I will check myself.
Go activate it and report back.
I used WinSCP for upload.
Regards
With regards
I understand that you installed another themes, and you had no problem. Did you installed any complex themes or just twentyeleven(or similar)?
As you can see, no other person have same problem so it is something in your server.
Back to the topic:
Make an account in WP for me, and send data via private message.
I want to see my self. I think it will have something with directory permissions.
