I find problem with works page when used scroller. Take a look in the attachment or go directly to the page
like here:
http://www.asmmedia.com/portfolio/fashionin first loading this page. When you reload page all images are displayed correctly.
This issue is in all works pages with scroller option on.
Thanks for answer.
Regards,
Sebastian
That is odd. I can see issue on your page but can't recreate it on my dev version. I will take a look at it.
Thanks for reporting.
Wit regards.
Maybe it's possible to add bricks option to works like third showing setup?
It will be grat when in the works we'll be have: scroller,slider and bricks to choose.
Now, I used alternate link in my works that going to gallery with bricks setted up.
But it's not good solution because it has other link, works navigation left right arrows didn't forward to gallery page, title isn't show etc.
Why don't you switch to slider option until I will find out why it doesn't work in your case? It also has titles, and everything like scroller.
If there is any possibilites to A13slider can use resized images unlike large images?
You mean like in single work? As slider is often full width, or undetermined width it may look worse in some scenarios. Please describe were you would want to use it.
Please take a look at the attachments.
You'll be find that images to slider is loading twice. One large size is loading trought code like http://media.asmmedia.com/content/uploads/2013/06/KSW18.jpg and second resized http://media.asmmedia.com/content/uploads/2013/06/KSW18-379x540.jpg.
I want loading only resized photos. Why use a lot of bandwitch to loading them twiced and in large size?
About main issue of this topic I think I have found fix for scroller issue and it will be released with new update. Update is done I am only waiting for some info from external plugin makers, before I can release it.
About your new issue(which should be in different topic as this are separate cases):
I can see that if JavaScript is disabled then both sizes are loaded. It is so that smaller one is treated as thumbnail and bigger is destiny of thumb. If there is JavaScript enabled then bigger one is used only.
Anyway I will check if this works as intended, and if not I will push it to new update.
Thanks for reporting. Next time, please start new topic on new case:-)
I didn't start new topic because I think is better to take any sliders and scrollers in one post. But of course in the future will be writing in separate posts.
Regards,
Sebastian
