will airlock work with wp 3.6?
edited August 2013 in Airlock Posts: 21
can you help me I just want to update wp 3.6 version, do you think will face any problem?
    I have made some tests and for now I am a bit concerned about its compatibility with WP 3.6. Hold one or two days, and I will check it out to be sure, and if possible I will prepare patch for WP 3.6.
    sure, I will wait for your update, thanks.
    & wish you a Very Happy Friendship day :)
    flyme said: wish you a Very Happy Friendship day :)
    Thanks a lot:-)
    You can update to WP 3.6 safely. Just use this updated patch in theme http://support.apollo13.eu/discussion/892/05.08.20013-updated-airlock-support-for-wordpres-3.5-and-newer
    can you just give an idea which issues are fixed by this patch?
    best regards
    Is there any list of issues that I could refer to?:-)
    JavaScript issues are fixed, cause with new WP versions there is new version of jQuery which is not always compatibile with older versions.
