I need help with How to set up my blog.
edited August 2013 in Hypershot Posts: 26
I have created a Page called "blog" and set the page under "reading" (in wordpress) to -> static page -> "post page" -> "blog"(page)
Under the theme settings: "Blog and Archives" -> Under "Blog Appearance" -> Blog Style. If I select "Masonry" Nothing displays on the folllowing page: http://www.viintage.com/blog
However, if I select "Classic" as the "blog style" then I see blog posts displaying on the page. Could you please help me figure out what I'm doing wrong?
Thanks in advance.
-Matt
    Hello
    I can see that non of JavaScript actions are working, so there must be JS error. Please deactivate plugins one by one and you will see which one is causing issue that masonry in not working.
    It seems that the issue is with s2Member. Which is crucial to my website. I guess I can just not have a blog. Thanks for helping.
    edited August 2013 Posts: 10,970
    If this is that plugin http://wordpress.org/plugins/s2member/
    Then it is rather odd that such up to date plugin is making problems(unless they did some nasty coding). Are you sure that it is that plugin?
    You can try to deactivate all plugins, and only enable s2Member and check then.
    If it will be still breaking theme, could you post linkto your page then, so I could see what its exactly doing?
