you know, you are asking for Google Analytic code but inserting it in wrong space. Google says it to insert in GA CODE . Please tell me how can i update it.
I was trying as with conventional Wordpress style i.e. editing header.php but nothing helped. I entered Google Webmaster code too but same. Its not showing anywhere. Adding this I have another thing to say that after editing header.php everything should be reflected in view source section but nothing shows up.
what is the hack can u tell me plz or tell me another method to insert it.
If you are editing source and nothing happens than it is something with your side, not theme :-) I don't understand where google advice to put code. Please explain "Google says it to insert in GA CODE". Anyway edit footer.php(line ~51), and take from it
Code inserted in theme should looks like:
to header.php or anywhere you wish. With regards.
