Hello Support,
I can't setup a portfolio page with portfolio posts correctly. The thumbnail for each portfolio post doesn't work - it shows a broken link as others have reported on this forum - or if I add a custom thumbnail it doesn't scale properly - the thumbnail is larger than the grey box when you hover the mouse over it.
Items that don't have any picture attached to them appear in the middle of the next section (about me on front page)
The back to portfolio link is broken as others have reported on this forum.
When you edit a portfolio post - in the Portfolio details section there is an option for Portfolio page (above slider yes/no option). You can't select an option for the portfolio page.
A fix would be appreciated,
B.
Could you send us a link to your website?
Kind regards
It just remains the issue with the Back to Portfolio button links to "/?pageid=" and not the proper page.
Also where can I edit the Link Text for this? I'd like it to say something other than "Back to Portfolio".
Same with the front page. Where can I edit the Title to say something other than "Latest Works".
Many thanks.
Get file front-page.php. About 112 line there is :
portfolio_get_icon(220, 150) - here you can set your icon size.
Kind regards
Back to portfolio: find string "back to portfolio" in file advance/apollo13.php and swap it with your string.
