LayerSlider seems to have a problem when editing slides, you can import the slides, and they work; but if you attempt to edit the slides you will get a blank page, this also happens when create a new slide, the slide is created but the end result is a blank page. I noticed on the LayerSlider support page that they released an update 5.0.1 on December 29. Are you planning to update your version? because as it stands right now, you cannot edit any slides once they are created/imported.
Yes, we will add to next update after or during weekend:-)
If you have access to this plugin independent of our theme then you can install it with no problem.
Unlucky right after release of our theme there was huge update of that page builder and it was incompatible with our changes. We will fix it, but for now we have more important updates that gives some new features instead of wasting time to fix this little annoying thing. But we will do it:-)
kreatura AUTHOR 22 hours ago:
Thank you for your time to look into this. The issue occurs in an external library, which we are planning to drop from LayerSlider in our next update. That should fix the problem you are experiencing.
