I removed the option to show the post date from the theme options, however, for the related posts beneath the single posts, the blog title appears and underneath that it says "Posted on" followed by nothing since the date was removed. Can this be removed as well when we choose not to display the date of the post?
I have just checked and switching off post date for blog or single post doesn't turn off date for this block(and it is good). You had to made something in code to switch it off. Do you recall what you might done?
Anyway in advance/utilities.php line ~1283 there is
.'<div class="post-meta">'.a13_posted_on().'</div>'
Remove it:-)
I removed the line and it worked perfectly. When I update the theme though, will it reset?
