Hey There!
I've been having a problem from about a couple of weeks maybe after an update, since I haven't got any problem before, If you go here
http://luiscastillo.net/work/ui/ you will see the images although being 2000px wide looks pixelate, it also happens here
http://luiscastillo.net/work/barcelona/ but in other work pages everything looks just fine.
Do you have any idea what may be causing this?
Best Regards.
It is hard to tell why, but indeed images used there are not full width, but some thumbnails sizes. And it is different size on both these pages you linked.
Have you tried deactivating other plugins?
All plugins are deactivated, I uploaded images after deactivating all plugins to see if now they are not rezised since I uploade them at 2400px width but it keeps on resizing them.
I deactivated the child theme to see if it was some modified css but it is the same in the parent theme. I don't know if it would be a good idea installing the theme again.
If it won't make any difference then I will try :-)
I 've reinstalled the theme the issue continue, no active plugins, but the images are still getting resized to 600px any idea?
