I've kept the theme updated but didn't realize I hadn't updated the included plugins. I updated them yesterday, however, since then I lost my home page (
http://www.christianbusinessacademy.com) along with navigation and the page linked to the top call to action button (next to navigation:
http://www.christianbusinessacademy.com/join).
I looked at the pages and all the modules are in place, but when I look at the published pages, they show up blank and the navigation is gone. When I go to other pages such as
http://www.christianbusinessacademy.com/about-us, the page and navigation show up just fine.
Can't figure out why these pages aren't appearing and yet others do. All that I did was update the plugins.
For sure you have some PHP error. Please enable debug mode as described here http://www.wprecipes.com/how-to-easily-enabledisable-debug-mode-in-wordpress or here http://codex.wordpress.org/Debugging_in_WordPress#WP_DEBUG
Also: What plugins have you updated?
Then come back to me:-)
Did the debugging and here's what showed up:
Deprecated: Assigning the return value of new by reference is deprecated in /home2/frebdayd/public_html/christianbusinessacademy.com/wp-content/plugins/wishlist-idcard/wishlist-idcard.php(12) : eval()'d code(3) : eval()'d code on line 2
Notice: wpdb::escape is deprecated since version 3.6! Use wpdb::prepare() or esc_sql() instead. in /home2/frebdayd/public_html/christianbusinessacademy.com/wp-includes/functions.php on line 3078
Deprecated: Assigning the return value of new by reference is deprecated in /home2/frebdayd/public_html/christianbusinessacademy.com/wp-content/plugins/wishlist-login/wishlist-login2.php on line 622
Deprecated: Assigning the return value of new by reference is deprecated in /home2/frebdayd/public_html/christianbusinessacademy.com/wp-content/plugins/wishlist-tabs/wishlist-tabs.php on line 259
Deprecated: Assigning the return value of new by reference is deprecated in /home2/frebdayd/public_html/christianbusinessacademy.com/wp-content/plugins/wishlist-tabs/widget.php on line 29
Fatal error: Call to undefined method WPBakeryShortCode_A13_Button::getExtraClas() in /home2/frebdayd/public_html/christianbusinessacademy.com/wp-content/themes/ChristianBizAcademyTheme/vc_templates/a13_button.php on line 44
When I did the page showed up fine (with all the shortcode text from the visual composer) so it seems that this plugin is the issue. Once the page showed up again, I re-installed the plugin via the theme plugins and the page was blank again and showed a blank menu.
It's definitely the plugin. Had the plugin active with no other plugins active and it still gave me the same problem so it doesn't seem like it's conflicting with other plugins since they're all deactivated except for this one (Visual Composer).
Have you used child theme? Version of theme used? Any customizations? Theme won't allow deactivation cause it is required for it to work.
I know this issue wasted lot of your time:-S Thank also for reporting this!
