After the most recent update, somehow the styling on the accordion went all out of whack. I believe it is a conflict between the theme's code and Visual Composer's code, as one feeds images for the toggles and one feeds FontAwesome. Now, after the last update, both are showing.
Can you issue a fix? I'll submit a link and screenshot in private comment.
Here is a screenshot. Page for reference: http://bit.ly/1lCRWfO
Thanks for link and screenshot - it was really helpful!
I have checked this and in my version in works ok.
I see you have compressed CSS files, probably by some plugin.
I also see that in your site, styles of builder and theme are loaded in different order then they should. This is reason you see this issue.
Please experiment with switching off plugins until it will look good.
