Problem at footer
edited April 2012 in Airborn Posts: 1
Hi there. The version 1.2.5.1 is not working on wordpress 3.3.1 or 3.2.1 too. We tried to install by uploading the zip file and it didn't work. So we managed to install extracting the files into themes folder. But the footer area is broken. See attached picture. Could you help us.
1137 x 606 - 43K
    Hi. I can see you are fighting on local server. In that case I can't help you, as on my installation everything works OK. Try to install it on public server and reproduce this issue. If it will happen, then we can try to fight it.
