Problems with plugin Twitter
edited July 2014 in Adamant Posts: 18
Greetings! I installed the theme, everything is perfect but moment trying to configure the plugin Twitter gives me one error, and set the consumer key and consumer secret, someone knows why is this happening?
http://i.imgur.com/naP9G1L.png
Post edited by Jorge02 on
    I'm trying to work this one out also
    Hi Jorge02,
    could you post some more details?
    The screenshot shows no error.
    Did you searched through the documentation and support of this plugin?
    Please check https://wordpress.org/plugins/twitter-widget-pro/
    Now it repaired! Twitter in the app you have to add your URL to the section "Callback URL" with this problem is solved, this does not have plugin support
