Hello. I'm having a problem with the header mini-cart, the button "Go to the shop" is the only thing that won't get translated. I did the translation following your instructions on the documentation, editing the .po file, and there is a "Go to the shop" line, but it doesn't work. It's strange because when I open the webpage for the first time it shows in spanish (the language I'm translating to), but then it changes to english again. Everything else got translated succesfully.
If we can't solve this, is there a way to delete that button? I don't care if it doesn't show up in my web, but I can't have text in english. The url is
http://diapolshop.wadstudio.com .
Thank you!
It is strange and sound like Woocommerce issue, but I will investigate this closer. To hide that button you can use custom CSS solution from this answer http://support.apollo13.eu/discussion/comment/9511#Comment_9511
https://www.google.pl/search?q=woocommerce+mini+cart+translation&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:pl:official&client=firefox-a&channel=sb&gfe_rd=cr&ei=eD45VJqDC4SJ8Qfx24DYCw
Keep your fingers crossed :-)
So I think that if you translated both woocommerece plugin and our theme, then maybe this kind of "cache" keeps you away from seeing result.
As for Payment method it comes directly from woocommerce, and there is no Ajax(as far as I know) so there shouldn't be same problem like in case of header mini-cart.
I will have to work closely with you to find out what is really going on :-)
As for the payment method, I've changed it on the code and it just worked
Many thanks
PS: tried to buy you a coffee but I don't understand polish paypal
Edit:
Thanks for info about language, it should be better now. I thought paypal is smarter;-)
