I'm having trouble adding a new type of ribbon in my child theme. On my advance/utilities/woocommerce.php I've added this:
if(!function_exists('a13_is_product_colored')){
function a13_is_product_colored() {
global $product;
return is_object_in_term( $product->id, 'product_tag', 'colores' );
Right below the "a13_is_product_new" function So far, the child theme works, but when I try to change this:
if(!$product->is_in_stock()){
echo '<span class="ribbon out-of-stock"><em>'.__( 'Out of stock', 'woocommerce' ).'</em></span>';
else{
//sale
if($product->is_on_sale()){
echo '<span class="ribbon sale"><em>'.__( 'Sale!', 'woocommerce' ).'</em></span>';
//new
if(a13_is_product_new()){
echo '<span class="ribbon new"><em>'.__fe('New!').'</em></span>';
if(a13_is_product_colored()){
echo '<span class="ribbon colores"><em>'.__fe('Más Colores!').'</em></span>';
On the woocommerce/content-product.php file, the theme stops loading any page.
You can check it on my site: www.pimuh.com
Thanks in advance
Please activated debug mode to see what PHP error occured.
http://codex.wordpress.org/Debugging_in_WordPress#WP_DEBUG
Then we can talk :-)
PS. Nice going :-)
Great! it worked! Many thanks!
On the other side, when i try to change the advance/utilities/woocommcerce file, in this line
<p class="buttons empty"><a class="a13-button" href="<?php echo get_permalink( wc_get_page_id( 'shop' ) ); ?>"><?php _fe( 'Go to the shop' ) ?></a></p>
I can't find a way to translate "go to the shop". I've edited the po fil, I've changed both fame and fame_child files, and it still shows "go to the shop" on my page
It was this topic http://support.apollo13.eu/discussion/2496/translation-problem/p1and can continue there talking about this to not mix different cases in one topic.
But I will test again without WPML to check how it works then.
