Problem after 1.2.0 upgrade
edited October 2014 in Blame Posts: 5
Hi, Earlier this week I have upgraded my theme to 1.1.1 without any ptoblem. Today I tired to upgrade again to lastest version but I got some problems as can be seen at http://www.klokke.com.br/quem-somos/ Upgraded via 'Easy Theme and Plugin Upgrades' and got no error message, but when I opened my pages, it seems the icons images can't be found (my uploaded images works) . Also, visual composer opens a blank bage. Other features seems to be ok.
- UPDATE I actually use a cookie free subdomain for static content. On previous version (1.1.1) there was no problem, but on 1.2.0 I get the following output:
"NetworkError: 404 Not Found - http://www.klokke.com.br/site/wp-content/plugins/go_pricing/assets/css/go_pricing_styles.css?bc915a"
Font from origin 'http://static.klokke.com.br' has been blocked from loading by Cross-Origin Resource Sharing policy: No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'http://www.klokke.com.br' is therefore not allowed access.
So I disabled my static subdomain, now the fontawesome icons  appears correctly but I still get the above error forthe following asset:
 http://fonts.gstatic.com/s/opensans/v10/DXI1ORHCpsQm3Vp6mXoaTRa1RVmPjeKy21_GQJaLlJI.woff
and visual composer still presents a blank page, debug shows following message
Fatal error: Cannot redeclare layerslider_init() (previously declared in /home8/aceforge/public_html/klokke/site/wp-content/plugins/LayerSlider/wp/shortcodes.php:6) in /home8/aceforge/public_html/klokke/site/wp-content/plugins/LayerSlider/wp/shortcodes.php on line 47
thanks
Post edited by felipeftd on
    Hello there:-)
    Nice site:-)
    felipeftd said: "NetworkError: 404 Not Found - http://www.klokke.com.br/site/wp-content/plugins/go_pricing/assets/css/go_pricing_styles.css?bc915a"
    For this please deactivate and activate again go pricing tables plugin.
    felipeftd said: Origin Resource Sharing policy: No 'Access-Control-Allow-Origin'
    This is more server/browser settings. You can try to google about it.
    felipeftd said: Fatal error: Cannot redeclare layerslider_init() (previously declared in /home8/aceforge/public_html/klokke/site/wp-content/plugins/LayerSlider/wp/shortcodes.php:6) in /home8/aceforge/public_html/klokke/site/wp-content/plugins/LayerSlider/wp/shortcodes.php on line 47
    Have you updated visual composer after updating theme? More info here http://apollo13.eu/docs/blame/#!/installation_update_update_theme
    However this error looks like some problem with Layer slider. Please deactivate it for now, check if page will work. If yes then try to activate it again.
    Also if you have any cache plugins then probably you will have to clear cache.
    If there will still be problems come back to me:-)
  • edited October 2014 Posts: 5
    Hi Air, thank you for your help.
    -Gopricing error gone away with that procedure.
    -The solution to that Origin Resource Sharing problem was to add 'Header set Access-Control-Allow-Origin "*" to .htaccess
    -Yes, visual composer was updated. When I turn LayerSlider off, visual composer works. Turning it back on, problem returns. Cleared all caches (W3TC), but no way. May I remove this plugin and install it back from blame\advance\plugins?
    Glad to hear that:-)
    Yes you can try to reinstall Layer slider by using plugin from this location. However this is strange. Are you sure that this particular error shown up after theme update?
  • Yep. After 1.1.1 upgrade everything was fine.
    I will try to reinstall the plugin later..
