when I open for the first time the site (in safari mac) does not show in the footer the text, if I reopen the text appears.. You see attached.. In the (explorer 11 windows) if I open for the first time the site not appear the icon.. You see attached
Regards,
Andrea
Can you recreate same issues, when you are logged as admin in those browsers?
regards,
Andrea
I don't have access to any Mac, however all issues that clients report on it I can always recreate on Windows Chrome browser.
Anyway I tested IE 11, and all other browser on your site, I also checked it on several computers and couldn't recreate the issue.
Have you installed any cache plugins, or other that try to optimize styles?
I also open your demo with chrome mac and same problem.. The problem is present only when open the site for the first time..
After, switch down and switch up and the text show..
Regards,
Andrea
I will reply when I will know something new.
EDIT:
It looks like it is some rendering issue on webkit, but it is hard to debug what exactly make this lack of "layout repaint" as I can't get this issue every time.
I will be happy if you understand the problem I await your reply.
regards,
Andrea
SOLUTION:
-Get attached file and unzip it
-upload file script.js to photon-a13\js\
-Refresh cache in your browser
-Done
When CDN will refresh in about one hour, also on our demo it should work fine.
Great work.. Seems to work fine..
Ahh.. One question.. Why in ie (windows) I see in preload background the images of the photographic camera? I delete all cache and in admin I delete the background image on preload, but the image is present.. Any idea?
Thanks again.. Ragards,
Andrea
No, no plug-in installed. Where can I find this setting?
Regards,
Andrea
Please try again go to custmoizer and change background image of preloader.
If this still wont change anything then please send me temporary access(create new ADMIN account with fake e-mail) to your WP so I could check there what is going on? Send it here on forum via private message(click on my nick, in top-right corner you will find option "Message"). In message please attach LINK(!!!) to topic it applies to.
ok.. When I have a second try. Thanks for all..
Regards,
Andrea
