My site was a vew versions behind 1.7.2 so i upgraded the theme. After doing so i experienced the same error as on this thread:
http://support.apollo13.eu/discussion/3419/fatal-error-on-newest-upgrade#latestHowever, whenever i try to updates the plugins i am presented with this error:
Downloading update....
Download failed. Unauthorized
Plugin not activated. A higher version of WPBakery Visual Composer is needed for this theme. Please update the plugin.
I experience the same with the other plugins which are out of date, just telling me i "Unauthorized". Could you please tell/show me how to fix this please?
Many thanks.
Yes some of these premium plugins not work with updater, probably cause they have they own update scripts, and maybe they get in conflict. Anyway manual update using files in
fame/advance/plugins
is best approach in this case.With kind regards.
