I like this theme, but i am having a few problems: 1: shortcodes for adding video do not allow me to change frame size. 2: latest works do not show portfolio items in home page even though i have them enabled . 3: latest blog post link color does not change it stays the same as original theme. Im sure it is something that i may be missing. thanks in advance
Hello, what about your problems: 1. there is no option like this at this moment. What want you to achieve? 2. They will show up after you add 4 works. 3. can you give me link to your page?
I have tried altering 'h3.latest_blog_post_topic', but the color doesn't take, even with '!important'. I actually changed the HEX code in the stylesheet itself, and copied it over to the child theme - that didn't work either.
Hello, to change h3.latest_blog_post_topic you have to edit apollo13.php file. We generate this css by php because you can edit this color by admin panel.
I can edit id by the admin panel? Where? I have set every color on the page=apollo13_color_options page to red, yet the text still shows up yellow/brown.
thanks very much for the new update and fixing the 9 image max problem for portfolio items. I really love this theme.
I am still experiencing the problem with the link colours mentioned above. Even though I have selected a colour for all links, I still get a few original brownish ones on the homepage: http://julemueller.com/
Best,
Miłosz
Any word on this?
I also noticed the search field is a bit long on the right side, and the outline clips off on phones.
Best,
Miłosz
Is the Wordpress theme editor ( /wp-admin/theme-editor.php ) basically useless with this theme?
you right, this is problem with theme. We are going to release update today.
Theme editor don't work with our theme. To change search input width you need to edit css file.
Best,
Miłosz
Can you help with this?
Thank you. Jule
thanks for info. I will fix it as soon as possible.
Best,
Miłosz
