Hi, can you please check this out?
www.antonellos.gr
Translated with WPML
Using the plugin "Sell Media"
In English everything works perfect
In Greek language when i'm adding something to the cart, the button for the checkout appears but not the text or the link for the check out page...
The support from Graph Paper Press told me that "...the theme is causing an error with AJAX loading."
The yellow button on the left is empty .... and of course i cannot go to check out.
Having another problem with the plugin i turned off "Dynamic site loading(AJAX)" and "AJAX when admin bar is active" and now its working!
I have checked it here http://www.antonellos.gr/eshop/korthi-kindergarden/?lang=el&id=2437
And indeed it doesn't show up. However I don't see any error and I don't know plugin that you are using here.
Did they told you more what exactly is the issue, cause I don't see any reply from server.
