Install Required Plugins problem error cURL error 28: Connection timed out after 10000 milliseconds.
edited September 2016 in Chillout Posts: 3
An error occurred while installing Custom post types for Chillout wp theme: Download non riuscito. cURL error 28: Connection timed out after 10000 milliseconds.
Post edited by lenuit_ on
    Hello.
    This possibly means problems with folders, file/folder permissions or smth like this. Please send me private message with login credentials to WordPress admin panel and FTP access - I'll try to fix that for you.
  • ok!
    You have few extra plugins, try to deactivate them and check how your WordPress installation works.
  • I did this test but does not work
