I use the plugin Ajax Search Pro from
https://codecanyon.net/item/ajax-search-pro-for-wordpress-live-search-plugin/3357410I have the problem that in your theme the replacing of the default theme search bar is not possible easy
In the Post
https://wpdreams.gitbooks.io/ajax-search-pro-documentation/content/general_settings/replacing_the_default_theme_search_bar.html it says that
"this method is supported by 99% of the themes out there. If the default search bar is not replaced after choosing one of the options, you will have to replace it manually in the theme code."
in:
https://wpdreams.gitbooks.io/ajax-search-pro-documentation/content/getting_started/search_shortcode_in_themes.htmli dont know how i edit to add the widget with the shortcode [wd_asp id=1]
into the line 291 in fatmoon\advance\utilities\header.php
"( $header_search ? '<div id="search-button" class="icon-search tool" title="' . esc_attr( esc_html__( 'Search', 'apollo13-framework' ) ) . '"></div>' : '' ) ."
Can u help me again, pls?
Problem with our search is that it appears after click in button that opens it. So we are probably this "1%". Have you tried with
do_shortcode
like in your other topic? With kind regards.But to my surprise the Ajax functionality dont work. I dont know why.
I use then the search plugin in the hidden-sidebar.
But now the Problem is that in the mobile view (with iphone 6s) there are inconsistencies. The search results do not disappear immediately, and everything becomes slower, the resolution also changes.
In Desktop View everything is okay.
with "( $header_search ? do_shortcode('[wd_asp id=1]') : '' ) ."
but the plugin dont react in the field.
I don't think I will be able to help you with all those problems, as this out of scope of theme support and it looks like lot of small tweaks is needed to make it work as you wish. Small doesn't mean easy ;-)
About Ajax search - theme works fine with different free plugin that has similar functionality http://apollo13.eu/docs/apollo13_framework_theme/#!/plugins_search_live_results
I've discovered in the theme support for the overlay menu.
In header.php
( $menu_overlay ? '' : '' ) ."
Can I at least know how I can activate instead of the main menu a widget with a short code?
Sorry that I bombard you with many questions
If yes, then I don't know:-) But hopefully you mean something else. Good for you :-)
Https://codecanyon.net/item/ajax-search-pro-for-wordpress-live-search-plugin/3357410
I asked:
Can I at least know how to use a widget with a short code?
I've been badly expressed, sorry.
The Menu Overlay display the Main Menu.
Link: http://apollo13.eu/docs/apollo13_framework_theme/#header_menu_overlay
Is it possible to display a widget instead of the Main Menu?
Thank you for your efforts
However you are right it is Offtopic. http://apollo13.eu/docs/apollo13_framework_theme/#!/widgets You can use widget "Shortcode" add there you shortcode and add it in sidebar that you want. If I understand you right and you want to change menu displayed in overlay with something else, then you can do it in fatmoon\advance\utilities\footer.php line ~162
and instead of all that code: add your
do_shortcode
or other thing. About displaying widget - that is for sure possible but I don't know the code.With kind regards.
