Problems in displaying text in product card while scaling
in Photon Posts: 48
Maybe, if it's not a difficult question for you, can you suggest something on this problem in displaying text in product cards (the image is attached).
This happens during scaling, when the card becomes less.
Maybe it is possible so that text will scaling too, with product card...
pobeda.life/product-category/pcheloprodukciya/eco-poselenia-rossii
1031 x 468 - 195K
    If you want to use so many bricks on such small width than you will have to tweak CSS for text, as it will not scale down automatically.
    Thank you for answer.
    I don't know why but here (screenshot) everything is good....
    pobeda.life/katalog/narodniu-promisel/dekorativnoe-ukrashenie-solnishko
    1068 x 724 - 202K
    PavelT said: I don't know why
    Cause there are 3 bricks in row and on your first link was 5 bricks in row. So there is much more space in second link in each brick :-) So either you have to change number of bricks universally or tuning CSS.
