Post format - does not work
in Photon Posts: 1
Hello, I have a problem with the format for posts. Once I select the gallery format, I do not have the option to enter the gallery for the posts. I can only add a thumbnail image. I would imagine that instead of the thumbnail picture it will be a slide that the user can change with the arrow keys and change the photo. This is an option in other wordpress templates. Is this option also in the Photon template?
Thank u.
Marek Duda
1738 x 696 - 175K
    Post format option doesn't do much, but only change small things of how post is displayed on Blog. Some theme maybe have some additional events for post type, but these are their features.
    jimbarris said: Once I select the gallery format, I do not have the option to enter the gallery for the posts
    About that - you add gallery as usual in WordPress https://codex.wordpress.org/The_WordPress_Gallery
