Problems getting theme lightbox to work
Previously I used the theme lightbox to show images in work (in fatmoon - www.martinkaufmann.dk/work) and it worked fine.
I have updated to SSL and mane of the plugins as well as fatmoon theme itself. Somehow along these updates I can now see the theme lightbox is not working properly. Clicking on a thumbnail (e.g. on this page: https://www.martinkaufmann.dk/work/ofelia/) I get the image shown... but not in the lightbox way and without navigation etc.
I can disable theme lightbox for media grid and the built in WP lightbox takes over working fine. But I like the theme lightbox and hope to get it working again.
Any suggestions on how to solve the issue?
All the best,
Martin
2047 x 1358 - 801K
    Don't worry, I have fixed this yesterday, for different topic, and you are in good place and time, cause today we are releasing massive update ;-)
    So hold on few more hours!
  • Thanks a lot :-)
  • Hi again,
    Thank you for the update - it now works as planned on a traditional computer but not when I try it on iPad or mobile phone (Android).
    On iPad/mobile phone... when I touch one of the images in an image grid the screen freezes shortly and then nothing. No image is shown.
    Do I need to change some settings or?
    All the best,
    Martin
    Dang it, you are right. I will not be able to fix it right now, however you can:
    1. try this fix, go to js/script.js line ~4234 and change:
    //block VC actions that force to open image native
    grid_items.on(click_event, function(){
    return false;
    to
    grid_items.on('click', function(){
    return false;
    I am not sure it will work, but worth a try. Be sure to clear cache.
    2. Just turn off theme ligthbox for media grid until I fix it: Customizing -> General settings -> Lightbox settings -> Use theme ligthbox for Media Grid
    Thanks for feedback.
  • Hi :-)
    Just want to hear if you can give an estimate on when the bug will be fixed.
    All the best,
    Martin
    As you can see on top of support forum, I am currently not available, so I can only answer questions, from time to time. When I will get back, then I will check what can be done.
    Have you tried my solution? Can you give me some feedback does it work?
  • Hi and sorry for the late response...
    I did not try your proposal but waited and now very pleased to see your updates make it all work again. Thanks :-)
    All the best,
    Martin
    That is great to hear!
