a few days ago, we launched this webshop using fatmoon:
http://www.urbexery.com/everything (more or less) works fine and we are very happy!
but, we have two problems:
01. we added the page "cart" as a submenu of "shop". when we hover over "shop", the submenu stays invisible.
when i take a look at the sourcecode, the submenu is included. but it stays hidden.
02. we are using the woocommerce mini cart widget inside the basket sidebar. as soon as you enter the checkout page or view your cart, the popup mini-cart is empty.
so there is not really a convenient way to return to the cart if you want to change anything...
thank you very much and with kind regards from germany
Uwe
Our theme sub-menus work on click, not hover :-) You will have to add sub-menu openers.
You can enable sub-menu opener in Customizer -> Header settings-> Main menu -> Submenu/mega menu opener icon
If you want to make whole "Shop" link clickable then mark option Make this item normal text(will not be link) -> http://apollo13.eu/docs/apollo13_framework_theme/#menu_enhancements
Yes, WooCoommerce disable it on checkout page, so there is nothing we can do. However I agree that it is confusing decision from WooCommerce side.
Thank you very much. Now i understand how your submenu works.
Regarding the mini-cart, i will include a permanent cart link into the main navigation.
Also, i try to include a "back to cart" link at the end of the checkout.
Thank you for your help and with kind regards
Uwe
I have just played around with code, and if you will add such custom css: Then it will add hover opening to submenu.
Please tell me what do you think:-)
"Click to open" has advantages that subemnu doesn't disappear if user moved mouse to far, but hover faster unravels submenu.
However this hover is more "preview" then full solution, as it doesn't count edges of submenu properly in special cases.
