This week, the display of albums broke on my staging site, and the only thing I can conclude is that it was related to some plugin updates (only using the default ones that come with the theme). For example, on my home page (which is a simple slider album display) - the album and the header do not display anymore. When inspecting the page source, I was able to find this error, and am hoping you might be able to help me figure out the cause:
: Uncaught Error: Call to undefined function apollo13framework_make_slider() in /homepages/8/d718619715/htdocs/app719496042/wp-content/themes/fatmoon/single-album.php:158
Stack trace:
#0 /homepages/8/d718619715/htdocs/app719496042/wp-includes/template.php(690): require()
#1 /homepages/8/d718619715/htdocs/app719496042/wp-includes/template.php(647): load_template('/homepages/8/d7...', false)
#2 /homepages/8/d718619715/htdocs/app719496042/wp-includes/general-template.php(155): locate_template(Array, true, false)
#3 /homepages/8/d718619715/htdocs/app719496042/wp-content/themes/fatmoon/front-page.php(86): get_template_part('single', 'album')
#4 /homepages/8/d718619715/htdocs/app719496042/wp-includes/template-loader.php(74): include('/homepages/8/d7...')
#5 /homepages/8/d718619715/htdocs/app719496042/wp-blog-header.php(19): require_once('/homepages/8/d7...')
#6 /homepages/8/d718619715/htdocs/app719496042/index.php(17): require('/homepages/8/d7...')
#7 {main}
Here is the staging site home page URL if that's helpful:
http://sterlingandco.apps-1and1.com/
Have you overwrite some templates or function in child theme?
If yes, then I would suggest disable child theme, and then reimplement changes, as there where some code rewrites in 1.6.x to introduce new shortcodes.
