Masonry grid still not correct. Changing brick proportion doesn't fix it. I've tried every setting: 1:1, 2:3, 3:2, etc. Please see attached screenshot.
Strange, I have just tested and it fixes case for me.
By sending access to WordPress I mean: -create new ADMIN account with fake e-mail -set some password to this account -send me created login and password
Indeed it didn't work at first, but then I have noticed that you have various plugins so I have disabled 7 of them, and then it started to work. I suspect it was cache plugin fault.
Unfortunately, I seem to be having the same problem with the "works" grid. When I activate the plugin JetPack, the problem comes back. I've turned off the cache plugin.
Only by deactivating JetPack plugin will the "work" grid 1:1 brick proportion look correct.
JetPack is a must have, so how can I get 1:1 brick proportion to be correct?
It seems that "Photon" module of JetPack is causing this, cause we currently are using different way of resizing images. I will be working on this in upcoming updates to move Rife theme images to "native" WordPress, as it now gives much more power then in past.
However for now go to your admin panel yoursite.com/wp-admin/admin.php?page=jetpack_modules and deactivate Photon module there.
Please try:
Appearance → Customize → Works Settings → Works list → Choose brick proportion and set it to other value then Original.
Thanks for login data.
It will fix it for now.
