I can't seem to control the number of works to show on the homepage in works grid. Currently, it only shows the 4 most recent Works in the grid. I need to change it to show 6.
1. Could you show link to your homepage, so i could know how it is constructed? 2. If you use shortcode to display works please check https://rifetheme.com/help/docs/content-management/shortcodes/post-list/ 3. If you use classic Works list then you can set number of works in Appearance → Customize → Works Settings → Works list
