I've imported Coco Design following the instructions but it doesn't look quite the same. Menu has been doubled and some graphic and slider parts are missing out. http://1900968.perunturbo.pl/
For now what I can tell is that import is working fine with Elementor 2.0.16 but not with 2.1.x.
Till I will figure out what the heck they changed, please revert Elementor to previous version as explained below, and after this import design again: 1. In admin area go to Elementor -> Tools 2. Next click tab Version Control 3. Click Reinstall v2.0.16
Now import will work fine. After import you can update Elementor if you like - it will still work.
Just update in the situation: I have found what changed, and the update should be online soon.
Thanks for your patience.
