Hello. I have a problem with Apollo13 Framework Extensions. When I activate it, it starts to show me a lot of errors:
Notice: Constant A13FRAMEWORK_FILES already defined in /home8/nelbanet/public_html/wp-content/themes/fatmoon/advance/class-apollo13-framework.php on line 81
Notice: Constant A13FRAMEWORK_FILES_DIR already defined in /home8/nelbanet/public_html/wp-content/themes/fatmoon/advance/class-apollo13-framework.php on line 82
Notice: Constant A13FRAMEWORK_IMPORTER_TMP_DIR already defined in /home8/nelbanet/public_html/wp-content/themes/fatmoon/advance/class-apollo13-framework.php on line 84
Notice: Constant A13FRAMEWORK_IMPORT_SERVER already defined in /home8/nelbanet/public_html/wp-content/themes/fatmoon/advance/class-apollo13-framework.php on line 85
Notice: Constant A13FRAMEWORK_GENERATED_CSS already defined in /home8/nelbanet/public_html/wp-content/themes/fatmoon/advance/class-apollo13-framework.php on line 88
Notice: Constant A13FRAMEWORK_GENERATED_CSS_DIR already defined in /home8/nelbanet/public_html/wp-content/themes/fatmoon/advance/class-apollo13-framework.php on line 89
Warning: Cannot modify header information - headers already sent by (output started at /home8/nelbanet/public_html/wp-content/themes/fatmoon/advance/class-apollo13-framework.php:81) in /home8/nelbanet/public_html/wp-admin/includes/misc.php on line 1126
I tried to delete the plugin folder and installing it again, but it doent work.
Thank you
Please update the theme and it will be fine :-)
https://rifetheme.com/apollo13-framework/docs/installation-updating/updating-theme/
If you haven't installed Envato plugin with the theme, please update manually as described below:
First download new version as described in installation https://rifetheme.com/apollo13-framework/docs/installation-updating/installing-theme/
Next, update: https://rifetheme.com/apollo13-framework/docs/installation-updating/updating-theme/manual-theme-update/
Everything is in documentation ;-)
Notice: Undefined property: WP_Post::$filter in /home8/nelbanet/public_html/wp-includes/class-wp-post.php on line 333
Warning: Cannot modify header information - headers already sent by (output started at /home8/nelbanet/public_html/wp-includes/class-wp-post.php:333) in /home8/nelbanet/public_html/wp-includes/pluggable.php on line 1218
I am not sure it comes from the theme, as none of these messages indicates a connection.
It could come from some plugin.
What do you mean by you "delete something"? Could you share more details?
