Shift Media in Works section to other section
Hi Support Team,
We can specifically insert the media we want in the Works page and the theme will automatically display them on top/above in the single work page.
However, we wanted to place them at the bottom of the page - Is that possible?
Besides, how can I disable the photo crop in the Media Grid? Even as I have set 1 photo per row, but the media is still clipped off.
Hope you can hear the questions I have had...
    ChristWolves said: Besides, how can I disable the photo crop in the Media Grid? Even as I have set 1 photo per row, but the media is still clipped off.
    Please check option Work details → Work media → Choose the proportions of the bricks and choose original size.
    ChristWolves said: We can specifically insert the media we want in the Works page and the theme will automatically display them on top/above in the single work page.
    You can do it by editing single-work.php file.
    Cut out line 109 that looks like this:
    apollo13framework_single_work_text_content($is_text_content);
    and inster it in line 36 so it looks like this:
    	<?php
    	// Disable default placement of addtoany widget but only in works
    	remove_filter( 'the_content', 'A2A_SHARE_SAVE_add_to_content', 98 );
  • This is working perfectly, just one last thing - How do I disable the overlay upon hover + drop effect on the photo in the grid?
    You can do it while editing Work in Work details → Work media → Hover effect and Work details → Work media → Show overlay - on hovert.
  • Excellent, got this. Thanks! :)
