I've upgraded my account to Pro and for some reason, the theme (Unicorn) is not being displayed properly. Please visit
http://scotthenrysholisticzone.biz/. This is very frustrating... I have a fresh install of Wordpress and thought upgrading to Pro would solve the problem.
It looks like Elementor styles are not loaded for some reason. Maybe it is an error on import.
Have you tried importing again?
If you have a fresh install, please try to:
1. Deactivate all plugins
2. Do import with removing current content https://rifetheme.com/help/docs/installation-updating/importing-designs/importer-configuration/#importing-demo-as-it-was-seen
Let me know did it help.
WIth kind regards.
Want to thank me with coffee?
To solve it quick, please rever to version 2.9.9 of Elementor, as explained here https://docs.elementor.com/article/382-rolling-back-to-a-previous-version-of-elementor
As soon as I will find out, what exactly needs to be changed to comply with the newest version of Elementor I will release an update. I believe the update will be in Apollo13 Framework Extensions plugin, so look out for the update. Hopefully, it will happen in 24 hours.
Sorry for the problems, I wasn't aware of their breaking changes.
Thanks for all the info!
You can now update to Apollo13 Framework Extensions version 1.8.5.
After the update, the import should work fine with the newest Elementor 2.9.14. I have tested this few times :-)
Thanks for all the feedback! At least you have now access to additional Designs to import and other features :-)
Air.
