Hi team,
Hope all is well. I wanted to know if there is a way to display the out of stock products last on the products galleries and on the product categories view. I couldn't find any information on this.
Currently the out of stock products appear in the middle of the products in my shop and I wanted them to appear at the bottom of the list. Is this possible?
Also, is there a way to ajust the ribbon size? As I'm currently using the Portuguese-BR version of the theme and the box doesn't cover the whole frase "out of stock" in the translation.
Here is the page:
https://romildosilvafilho.com.br/The current out of stock product is "PORTA CONTROLES ATLANTIDA"
Thank you so much.
As for the ribbon size, please add such custom CSS: As for out of stock items, this is more on the WooCommerce side.
I have found such code solution https://stackoverflow.com/a/44597448
I have tested it on my website by adding code in that answer to the functions.php file in the theme.
It works for me, but please test it.
I can think of it as an option for a Rife Pro feature :-)
Want to thank me with coffee?
Thank you so much for your help. The ribbon size didn't quite work but I found a different solution here: https://aceplugins.com/showing-a-out-of-stock-overlay-in-woocommerce/
It would be a nice addition to have the out of stock products coming in the end as a standard Pro feature.
Thanks again.
