Remove thumbnail from posts navigation on Single Post
in Rife Posts: 69
There was a similar discussion on this (https://support.apollo13.eu/discussion/comment/25947#Comment_25947), but the solution presented was to disable navigation. I would like to keep the posts navigation without the thumbnail.
Would appreciate your help on this.
TIA!
    Please add such a custom CSS:
    .posts-nav .image {
      display: none;
  • Thank you, Air, that worked. :-)
    Cheers!
