Hello - I am having trouble getting my twitter feed to show up in the footer widget area using the "Skyfashion Twitter" widget. The widget itself shows, but no the feed will not appear. The account is confirmed and I've waited several days to make sure that the account was active and able to be picked up. Any help? I don't know why it won't show.
http://www.stylemarketstudio.com/The only changes I have made to the template are to remove post thumbnails. The only plugins I've added are a pinterest and instagram feed, also for the footer area. However, the twitter wasn't working before i installed those either.
Many thanks for any help!
can you send me at support@apollo13.eu what you are pasting into Twitter Widget configuration?
Best,
Miłosz
