Portfolio Project Order
edited December 2011 in Airlock Posts: 95
Hi is it possible to reorder the Projects in the different Categories or in generell all works ?ß
thanks
    You mean to sort them by different thing then by date?
    Yes i remember there is a Plugin for reorder Posts for Blogtopics.
    But it wont work with your custom Portfolio Section.
    I would like to leave the settings ( Date, Name ...) like it is and in the Portfolio main Section ( My Portfolio )
    to drag and drop the post to the order i like.
    something like this illustration
    1301 x 812 - 598K
    Could you tell me what was name of that plugin? I will check what can be done in that matter.
    Hi of course
    Plugin: http://wordpress.org/extend/plugins/easy-post-order/
    I have tried it and it is possible to show the Posts of the Portfolio section and also to reorganize it, but on the Site nothing happens.
    944 x 576 - 281K
