Getting this problems under filer and other places.
Warning: stripos() [
function.stripos
]: needle is not a string or an integer in /home/j/jfp/www/wp-includes/functions.php on line 658
function.stripos
]: needle is not a string or an integer in /home/j/jfp/www/wp-includes/functions.php on line 661
Warning: stripos() [function.stripos]: needle is not a string or an integer in /home/j/jfp/www/wp-includes/functions.php on line 658
Warning: stripos() [function.stripos]: needle is not a string or an integer in /home/j/jfp/www/wp-includes/functions.php on line 661
You can see screenshots here
http://www.jfp.se/?album=bugg&preview=true&preview_id=3616&preview_nonce=b665d6ffde
if ( 0 === stripos( 'http://', $uri ) ) {
$protocol = 'http://';
$uri = substr( $uri, 7 );
} elseif ( 0 === stripos( 'https://', $uri ) ) {
Thanks for so much info, but it looks like some Wordpress or server issue. However lets try to fix it:-)
Do you have any plugins activated?
What version of PHP you have got?
Have this warning been visible from start?
Do you have any Genres in Albums?
Akismet not activated Version 2.5.7
WordPress Importer activated
2 Dont know about the PHP. How do i see that?
3 Yes the warning have been there from the start.
4 yes i have Genres. Sampel Genres and my own. like 5- 8 genres.
Settings-> Permalinksand set some other then default value.With regards.
