Visual composer issue
edited September 2014 in Blame Posts: 62
I'm editing a home page using visual composer. And I need a row with 5 columns where I will put 5 single images.
By default it has several options like 1 column, 2,3,4, 6 etc, but not 5 for some reason. I tried to make a custom layout input like 1/5+1/5+1/5+1/5+1/5, but unfortunately then it creates 1 column with 5 rows, not a row with 5 columns.
Do you have an idea why?
On the attached example you see a row with 6 columns.
Thank you in advance.
