I have checked this with firebug, and it is some div in row from builder. You will have to inspect it and search for unwanted content there. This div has class upb_row_bg.
If you can't do it I will help you with it.
Good luck:-)
What is random box there? You mean this content that looks like facebook timeline or fixed menu? Or am I not seeing something? :-)
upb_row_bg
.If you can't do it I will help you with it.
Good luck:-)
