kingcontent said: How to disable the icon hover
kingcontent said: The hover looks Its misleading for a click.
.title-icon:hover{ background-color: #D3AC13; border-color: transparent; color: #fff; -webkit-transform: scale(1.2) translateZ(0.1px); -ms-transform: scale(1.2);/* IE 9 */ transform: scale(1.2) translateZ(0.1px); }
i.a13-icon-blue{ color: #5472d2; }i.a13-icon-blue:hover{ background-color: #5472d2; }
i.a13-icon-white{ color: #ffffff; }i.a13-icon-white:hover{ background-color: #ffffff; color: #222; }
:hover
To disable it you will have to remove lot of CSS, or only this one that you use.
In style.css file line ~4000
remove this: and also in block under above code, which starts with: and ends with: remove every line with
:hover
.In next update I will add option to disable hover on this element.
