Like to have 5 columns on Home Page My Works section
edited October 2014 in Superior Posts: 27
Is it possible to setup 5 columns for the my works section on the home page- currently it only allows for up to 4.
I've tried changing it to 5 in the shortcode /teaser.php file but this didn't seem to work.
Can you please help with this?
    Hello there:-)
    I think that number of columns depends of current space available :-)
    So on mobile you will have 1-2, and on bigger screens more.
    If you would show me live link I will confirm that.
    Thanks for your reply,
    I see what you're saying but there is no option for further columns in the popup window. Only allows up to 4
    Sorry - can't show you live link yet as site is still in development.
    Is there any way to have the 5 columns?
    Regards,
    C.
    818 x 587 - 73K
    I think for now I've sold it by setting the grid carousel option.
    If you by any chance have another solution for showing the 5 columns I'd be happy to know.
    Cheers
    C.
    Hello again.
    I have checked and there is no way to do it in Works grid.
    Is there any special reason why you need 5 columns exactly ?
    Thank you for checking - only reason was because client wanted 5 items to show on the home page together but the carousel will solve this.
    Thanks for your help :)
