I can't update any image
edited July 2012 in Airlock Posts: 32
I use Version 3.4.1 and I have this error.
as I show u on the attached pic.
How can I fix it without update the old wordpress, please?
    Tell me how to reproduce this bug, cause I can't find what is causing it.
    edited July 2012 Posts: 10,970
    Btw are you logged as admin when doing this and getting error? Cause as I found only users that are not allowed to edit posts will get this meesage when they try to use uploader in any place.
  • I likewise am having the same problem could you please help?
    edited August 2012 Posts: 10,970
  • Hi, I did yes, I was in admin and in the past it worked. Set up a new user and made that editor it still came up with the same message.
  • Hi, i've updated to 1.7 and it seems to have fixed the problem.
    Hi notwiliam. That seems odd. If you encounter this issue again, please come back here. I will then ask you for some access so I could check this my self.
    PS. Where you in admin area or logged as admin in admin area?
    Thanks in advance and have a nice day :-)
