Hi, I got a fatal error after installing the YITH WooCommerce Zoom Magnifier plugin. Call to undefined function yith_wcwl_count_products() in ~/public_html/wp-content/themes/fame/advance/utilities/header.php on line 247
It looks that plugin author use same function for his different plugins and that is why our theme assumes that you installed wishlist plugin. I will fix this in next version. For now I see two solutions: 1. install Wishlist plugin from same author http://apollo13.eu/docs/fame/#!/plugins_recommendations_wishlist
2. But if above is not acceptable for you then I will prepare code fix.
Yes I know, you can have both installed:-) They just share common functions, and that is why you got error. However I have fixed this in newest update. Should be available tomorrow.
