Hi Air,
I would like to create my contact page exactly the same way as on your demo default template Contact III. How it's possible?
I've created a Contact page and then chose a template Contact(map full width) or (map content width), but it's not the same as on your example.
Thank you!
Template is only of proper behavior of map, rest is done with builder. Please tell me which of contact pages you wish to recreate and I will give you text that you will have to insert in text editor.
Use this link as base http://blame.apollo13.kinsta.com/ and paste here link of your selected page.
Thank you
Open the attachment and add this content to your contact page using the "Classic mode". (https://nimbus.everhelper.me/client/notes/share/108213/3lHch2X2iZDniZOHJgOFqNIleFsHZES6/)
Instruction:
1) Open and copy everything from attachment
2) Switch to the "Classic Mode" and past code from attachment
3) Switch back to "Backend Mode"
P.S Not all will be added. You need to add pictures
All the Best
Thank you!
