Hi!
Is there a chance (like CSS code in the custom CSS box) to add classes to all post images (or is it called article image?)?
I’ve installed a lazy load plugin to save bandwith and load times, but unfortunately, it messes up my blog overview by just loading the first two images.
The plugin offers to exclude certain images from the lazy load by giving them classes. But I have no idea how to add classes to post images as they are not integrated in the post itself and hence don’t have a code like
… that I can type in the editor.
You know what I mean?
Thanks.
If you want lazy load for blog then it is compatible with this plugin http://apollo13.eu/docs/blame/#!/plugins_recommendations_infinite_scroll - please also do configuration as explained there.
I actually already prepared for writing "well, yes … but I don’t like infinite scrolling on my website".
But as I know it from you: Your documentations and support just do exactly what we users are looking for. Now I have a plugin called "infinite scroll" which doesn’t scroll infinitely but loads lazily.
Awesome! Thanks!
So the theme has a built in lazy load function now, doesn’t it?
I read this topic and I know what is about but your recent question just left me clueless why there should be so :-)
"Lazy Load for Works List and Galleries"
Right here.
So to achieve the things discussed above, I will still need the plugin?
Yes, nothing changed in that matter :-)
