Sidebar Widget Question
edited November 2014 in Fame Posts: 17
Im just wondering how i can make the image size of some of the widgets the same size? I have a RECENT POST widget and the PRODUCTS widget for my sidebar and the image sizes are different as in the image i have attached. Where can i look to edit the dimensions of these images so that i can make them the same size. Thank you.
    Hi there:-)
    I think best result, in this case, you will get by improving posts image by custom CSS:
    .widget_about_posts .thumb {
    height: 80px;
    width: 80px;
    margin-right: 20px;
    It will be square but same width as shop images so it will be visually much better.
    With regards and have a good weekend.
  • edited November 2014 Posts: 17
    amazing that did the job! thank you so much. just one more question though. when i hover over the image for recent posts, it tends to have this popup effect with some shadowing. how do i get rid of this?
    and where can i edit the css to fix the width of the products image size?
    Post edited by tommychi on
    edited November 2014 Posts: 10,970
    These are two question and for second you better start new topic and explain what you mean cause I am not sure if you still ask about sidebar or something else:-)
    Hover effect - use this custom CSS:
    .quick-flickr-item:hover img,
    .widget_recent_works .item:hover img,
    .widget_about_posts .item:hover .thumb img{
    box-shadow: none;
    top: 0;
    left: 0;
    -webkit-border-radius: 0;
    border-radius: 0;
