I have been having a mass amount of problems with this theme/woocommerce and permalinks and it has been frustrating to say the least.
with woocommerce I finally got things working the way I wanted to with a workaround using a plugin called "custom permalinks"..I needed my products to show the links as follows & each category display the corresponding products on the page when clicked.
mysite.com/shop/productcategory/productSUBcategory/productname/
Actual working example:
http://mob84.com/shop/home-decor/pillows/aaliyah-reimagined-pattern-pillow/with the plugin I was able to edit my permalink settings to these
http://mob84.com/screen-shots/wp-permalink-settings.png& on the edit product page create the custom permalink so it linked to the right place...everything is working fine with the exception of my "Gallery"
For some reason I click the gallery page the gallery thumbnails show fine but when you click them they are set to go to
http://mob84.com/galleries/fall-2015/ and end up at
http://mob84.com/fall-2015/ casing me to get a 404 page.
I'm not sure what is going on or how to fix as honestly I am not to familiar with how permalinks actually work so it's a miracle I even got as far as I did getting the shop links to work correctly lol
It looks like you have permalink conflict.
http://mob84.com/gallery - can't be taken if http://mob84.com/gallery/gallery-2-columns/ you want to work.
Change you galleries list slug to something else, and then go to permalink again and click "Save" - it will refresh cache of permalinks rules.
If you still can't do it then please send me temporary access to your WP so I could check there what is going on? Send it here on forum via private message(click on my nick and there you will find option "Send Air a Message"). In message please attach link to topic it applies to.
what i want is for the gallery to be
mob84.com/gallery/
when you click the albums example: fall 2015
id like it to go to
mob84.com/gallery/fall-2015
I have tired rearranging everything but cant seem to get this setup I will PM you login info thank you for all your help!
