hi
i have this page
http://www.boazpic.anat-tal.net/album/אלבומים-דיגיטליים/when i see it on my computer
the image is not full screen - it's on the right side of screen
how do i fix it?
when i see it on mobile -
if the mobile is portrait its ok
but if i want it full screen and rotate my mobile to landscape - the image is missing
how do i fix it?
thank you
boaz.
I can see that on some resolutions it is indeed shifted right. I believe there can be two things that make it.
Either some plugin is making some additional manipulation, or your changes for RTL affects calculations of slider.
Are all your changes in child theme stylesheet?
i need the RTL change because it the way od reeding here.
all my changes in child theme.
can i fix it?
boaz.
i use Contact Form 7
Duplicator
thanks
now its on :
http://new.boazpic.co.il/album/שני-ועפרי/
but now the problem is that its to up in the window
the upper part of the image is cut out
what should i do?
thank you
what should i do about the footer? how do i push it down?
lokk on this site :
http://www.rivkaphotos.com
when you click on the secondary menu its open on fullscreen.
no way to do it on this theme?
Answer I gave you makes album fit between header and footer.
To go to fullscreen in our them you click in bottom right "hide layout".
Check here fro example http://hypershot.apollo13.kinsta.com/album/full-width/
my page look like this when fit album - fully visible like jpg-1 - it is to the right.
it is all the image but missing the right part
my page look like this when fit album -fit landscape like jpg - 2 it it in the center
but missing part of the upper and lower image.
what can i do??
Please add this custom CSS, and it will be fixed: With kind regards.
thank u very much.
on pc it looks great - like pic 1
on mobile it is amall - like pic 2
is there a way to fix it for mobile?
