Is there a way to have the custom background image resize itself (just like images in an album do), so that when you resize the window (or have a higher/lower resolution screen) the image continues to fill the screen perfectly and doesn't repeat vertically or horizontally?
Thank you
You can use such custom CSS to achieve this: or this one Add it as I explained in your previous topic :-) http://support.apollo13.eu/discussion/comment/10925#Comment_10925
